Rennline Strut Mounts
Hi all
Anyone use the Rennline strut mounts either/both front and/or rear? I need to replace the stock mounts on all four corners and the monoball's are not all that more expensive. I'm running PSS10's if that matters
Any appreciable difference in NVH?
If you installed yourself how bad were the rear nuts to access vs the stock one's?
Any other impressions?
Cheers
Cheers
Read through here.
https://rennlist.com/forums/964-foru...ns-please.html
Consider the information posted in post #9 and #14.
Thanks Vandit
That's food for thought. I don't need the extra camber. I also don't need the extra 20mm ride height
Did you ever install the mounts?
I just installed PSS10s on my 91 cab. I wasn't looking for RS ride height, just a good setup to lower a little all the way around. for the fronts I used the stock mount. The rears were a different story. I initially used the stock rear upper mount and found it lowered the car more than I wanted so I tried Elephant Racing rear upper mounts. Perfect for what I was looking for. Didn't really notice an increase in NVH.
http://www.elephantracing.com/suspen...hock-mount.htm
