Motor Oil suggestions for 964
#61
As I mentioned in another post, I use Shell Rotella 15W-40 diesel oil. Have used it in my old 911E, 911T and never had a problem. This was the factory fill on new cars.
#62
Two well regarded Porsche mechanics here in Oz recommend and use Castrol Magnatech 15-40 and 10-40.
This sort of debate will go on (always does) for pages. I really think (personally) there is no one size fits all as it depends on age of motor, driving style , environmental conditions etc. Just my 2c worth
#65
Anyone use Total Quartz 9000 5W40 (aka Elf 5W40)? The shop I use for projects too big for me used it after a major project and my engine was bone dry. Last oil change a couple weeks ago, I put in Joe Gibbs XP5 and now I've got some seepage on the valve cover nuts and the timing chain covers that wasn't there before.
#66
I use Total/Elf Syntetic 5W-40 which is an API SL; Quartz 9000 is API SN, meaning less ZDDP...
Works fine in my engine. Pressure (at normal operating temperature) is 5 bar @ 4500 rpm.
#67
Porsche Classic 10w-60
On a BMW Blog I did find some info on the Porsche Classic 20w50.
Porsche Classic Motoroil 20w50
Zinc: 883ppm
Phosphorus: 927ppm
Viscosity at 100C: 19.1
TBN: n/a
VERY interesting, as Porsche seems to say that ZDDP are not as important as we think they are?!
Those numbers are lower than any oil, anyone here uses...
Zinc: 883ppm
Phosphorus: 927ppm
TBN: n/a
I wondered if anyone (Undutched?) has found leaked info, or better yet, Blackstone tested Zinc & Phosphorous numbers on the 10w-60 as well?
I caveat & realize that the heat demands on the 964 Turbo's are not the same as NA,.. but thought I would cross-post the link to a discussion I've nudged along over in the other RL forum...
https://rennlist.com/forums/964-turb...-this-oil.html
The final few posts in that thread, are where I've ponied up some information that I've collected up to this point.
I am interested in all feedback from anyone who has tried this oil, &/or had any of it tested.
TIA,
=Steve
