964 Forum 1989-1994
New tyres causing understeer problem
Old Sep 16, 2003 | 05:57 PM
Greg_L's Avatar
Greg_L
Angry New tyres causing understeer problem
After having a fairly sweet (i thought, and was told) handling c2, i now have a lot of understeer.
I bought the car with cheap tyres. About three months ago i changed the rears (245's x 16) and the handling stayed similar only with more grip under power. On saturday i changed the fronts (205's) and all of a sudden i have lots of understeer. It dosent make sense to me why changing the cheap old fronts for more grippy (toyo proxes) new ones would increase understeer?
I tried filling the tank right up to see if the extra weight would give me a hint more negative camber to aid the problem, but it didnt.
I'm thinking the geometry might need looking at, but the car drives straight, does not vibrate or handle badly at any speed and the old front tyres were fairly evenly worn - maybe a little more worn on the inside lip.
Any ideas?
Edit - hot pressures 38f, 44r - i'm going to go out and try less pressure in the fronts.
Old Sep 16, 2003 | 06:04 PM
robmug's Avatar
robmug
Greg - what were the cheap brands?
Secondly, do you now have a set of 4 Toyos?
Thirdly - don't underestimate how long it may take to settle the tyres. JB will agree with this, it having taken CC track day to get his new rears to start gripping!
I'd give them a bit of time to settle...when are you off to the 'ring?
Old Sep 16, 2003 | 06:41 PM
John Boggiano's Avatar
John Boggiano
Lifetime Member
Very true - hundreds of miles needed to establish 'normal' behaivour of the new tyres!
(Was kind of fun though, wasn't it, Rob?!)
Old Sep 16, 2003 | 07:08 PM
robmug's Avatar
robmug
It was indeed!
Old Sep 16, 2003 | 07:10 PM
Greg_L's Avatar
Greg_L
After some testing, I think tyre pressures was the answer.
I should have experimented before posting, apologies.
My front tyres had cooled to 36psi & I let them down to 34. The rears still felt warm at 41, i inflated them to 43.
After a few roundabouts and hairpins had put more heat in them, the car felt much better. I checked the pressures again when i got back 36f, 44r hot. I still think there may be some of the protective oil on the new fronts - or just a little too much height in the tread, but needless to say, playing with the pressures made a noticable improvement.
Rob,
i have contisportcontacts on the rear (bought for 1/2 price thru a friend at conti - sadly he's now left ). They are wearing faster than i'd guessed so i decided to try toyo's on the front and will replace the rears with toyo's when necessary.
I had Michelin 'Primacy' previously - very average.
Off to the ring first thing on friday morning! Can't wait. I'm hoping to get some good video footage to upload to my site.
Old Sep 16, 2003 | 07:23 PM
Greg_L's Avatar
Greg_L
Hundreds of miles, really?
When i changed my rears they felt good after a 10 yard wheelspin out of the tyre place - on their recommendation!!!
Although I guess any sport tyre would have felt better than the "i-cant-sell-the-car-with-bald-tyres-quick-whats-cheap" tyres i previously had.
Old Sep 16, 2003 | 07:44 PM
scupper's Avatar
scupper
As detailed in my thread below (and based on recommendations I received from the group here), I changed from 205 to 225 fronts (and changed from Pirellis to SO3s) - the larger front size changed my understeering C2 to a wonderfully handling car on the track. I also decreased the tire pressure differential between front and back to 2 lbs. The difference was like night and day. I am running 17 inch wheels, however - don't know about 16 inch wheels but I would assume the principle is the same.
chuck
93 C2
Old Sep 16, 2003 | 08:59 PM
Greg_L's Avatar
Greg_L
chuck
93 C2
Hi Chuck,
Yes i did read your thread, and was not really surprised that the wider fronts gave more grip and therefore less understeer. I read on the boards here that 225 is pushing the limits for a 16 inch wheel, so opted to stay safe and go for 205 - as i'll be hammering them on track.
It is incredible what a small pressure difference between front and rear tyres makes on these cars though !
cheers,
Greg
Old Sep 17, 2003 | 04:07 AM
Cuppie's Avatar
Cuppie
DO NOT MIX TYRE MAKES or N RATINGS...............
How many times do you need to be told this........doh!
Melv
Old Sep 17, 2003 | 06:18 AM
johnfm's Avatar
johnfm
Must agree with Melvin on this one - mixing tyres gives incredibly noticeable handling problems. I don't know the theory, but the practice was enough to convince me that it is tomfoolery!!
Old Sep 17, 2003 | 06:40 AM
scupper's Avatar
scupper
Agree fully with the no-no regarding mixing tires! I am running FOUR SO3s, not a mix of Pirellis and Bridgestones.
Chuck
93 C2
Old Sep 17, 2003 | 06:41 AM
robmug's Avatar
robmug
Greg - they're right you know! It's not just whether the front or rear tyres are any good, but the relationship between the 2 brands/axles.
SOunds like you had some success with tyre pressures though, and the 'ring will give you every opportunity to evaluate the tyres properly!
Old Sep 17, 2003 | 06:53 AM
warmfuzzies's Avatar
warmfuzzies
Hello Melv,
How come it took so long for you to find this place?
Must agree with the sentiment though, mixing tyres is bad news, caused me no end of understeer when I first bought my C2. Horrid.
Kevin
Old Sep 17, 2003 | 08:21 AM
Greg_L's Avatar
Greg_L
I know mixing brands isnt ideal, but surely most important is having the same rubber on each end of each axle. As i said i got a deal on the conti's and wouldn't have chosen them out of choice. I expect to change the rears almost twice as often as the fronts, so i'm opting for Toyo tyres which i believe are far better value than conti's (£112 and £70 respectively for the fronts) and magazine tests have marked the toyo's better all round.
After some pressure tweaking and testing, i'm now happy with the results. I don't think the differences between Z rated sport road tyres are really going to be huge for road and some amateur track use. This is not motorsport.
Old Sep 17, 2003 | 08:42 AM
JW Hubbers's Avatar
JW Hubbers
Default Videoing at the Ring
You'd better look into ways of mounting your camera AFTER going through the gate, or use a bullet camera. As of late last year videoing during tourist hours is forbidden
I look forward to the footage, though
Have fun!
Cheers,
JW
