964 Forum 1989-1994
Rsamerica suspension upgrade/replacement
Old Aug 10, 2015 | 11:04 AM
rsamerica911's Avatar
rsamerica911
5th Gear
Default Rsamerica suspension upgrade/replacement
Looking for some advice. My rs has stock suspension with lowering springs. One of the lowering springs broke. So while I'm in there replacing the spring, I was going to replace the shocks as well. What do you guys recommend. The car will be mostly street driven, but there will be some track days as well. Should I just replace the shocks and get new lowering springs and what do you recommend on that. Or does it make a huge difference going with a coil over set up like the kw's. And if you do recommend the kW's, what model number do you recommend.
Old Aug 10, 2015 | 11:53 AM
GBX's Avatar
GBX
Just put KW V3's in my C4 and really loving them! Amazing for a street car, but I'm sure they would also be great on the track, if set up appropriately. AutoTalent in CA is offering a great deal on these currently. Happy to provide info if you're interested.
Old Aug 10, 2015 | 12:06 PM
Vandit's Avatar
Vandit
If you intend to stick to the shock and spring combo, everyone's go-to is Bilstein HD shocks, but Koni Yellows are supposed to be another solid choice (just not as popular).
Old Aug 10, 2015 | 02:30 PM
rsamerica911
5th Gear
Yeah I definitely be interested.
Old Aug 10, 2015 | 06:10 PM
GBX's Avatar
GBX
PM sent.
Old Aug 10, 2015 | 08:31 PM
rdean's Avatar
rdean
I installed KW V3s on my RSA last season..Result, more composed than original equipment. The 2 adjustments option provide for plenty of options on and off the track.
Very pleased.
