Share your KW's
This is an oldie- all of my suspension & alignment settings have changed drastically from above.
You can reach the bottom (compression) adjuster by lying on your back and reaching underneath. Front top (rebound) is obviously easy. Rear has a few options-
Rear left:
Using the RS heater blower bypass tube, it’s accessible to reach.
Mount an extender, such as:
https://www.kwsuspensions.net/produc...ories/68525024
Otherwise, the heater blower has to be removed to reach the adjuster.
Rear right:
It’s easy to reach if you use a Cup style air filter cover (not the problematic carbon fiber junk).
Or extender as above.
Otherwise, the air filter and cover have to come off to adjust.
Rear left:
Rear right:
