964 Forum 1989-1994
suspension setups
Old Jun 28, 2015 | 07:20 AM
davidwilson11's Avatar
davidwilson11
Default suspension setups
Howdy folks,
New coilovers have arrived and I'm now turning attention to installing them and a full geo afterwards.
Do you guys have any off the shelf geo numbers that I should use. Track and road and would like it fairly low. Now slammed but low.
Old Jun 28, 2015 | 08:36 AM
Strega(UK)'s Avatar
Strega(UK)
I would get it setup to factory geo numbers but with RS ride height,
Old Jun 28, 2015 | 10:21 AM
Vandit's Avatar
Vandit
Read through the suggestions in this thread.
https://rennlist.com/forums/964-foru...and-setup.html
Old Jun 28, 2015 | 01:15 PM
davidwilson11
Cheers guys, I'll have a good read.
Old Jun 29, 2015 | 10:12 AM
964George's Avatar
964George
RS settings as follows
Front Axle:
Height: 125mm +/-5'
Toe (total): +25' +/-5'
Camber: -1deg +/-10' max difference left to right: 10'
Caster: +4deg 25' +/-15' max difference left to right: 15'
Toe difference angle at 20deg steering lock: 1deg 50' +/-30'
Rear Axle:
Height: 223mm +/-5'
Toe (each wheel): +15' +/-5'
Camber: -1deg 15' +/-10'
