964 Forum 1989-1994
different RS Shifter length?
Old Jun 9, 2015 | 12:05 PM
FlyinTomato's Avatar
FlyinTomato
Default different RS Shifter length?
I recently purchased a short shifter kit from a rennlister. I believe that's the FDM kit. with the heim joints. FDM kit modified the RS shifter to use to the heim joint. upon receiving the kit. I found that the FDM kit shifter is shorter than the RS shifter, I have a RS shifter in procession to compare the two. I've also compare the RS shifter to a FDM kit that Mr.alex bought. Both of the shifter are the same length.
So, any chance that the FDM kit I bought has a different version of the RS shifter? I do like the taller version of the two better
My FDM kit vs RS shifter(with ball)
RS shifter vs stock, see the position of the two is much different. picture i found on the net
Old Jun 10, 2015 | 04:16 PM
Metal Guru's Avatar
Metal Guru
Based on the pivot position of the FDM shifter, I'd say it won't give you the short shifting that you desire.
The factory short shifter will give you short shifting but it isn't a dramatic difference. The shifter is longer from the pivot up to lessen shifting effort.
Old Jun 10, 2015 | 06:16 PM
FlyinTomato
I can modified the factory RS shifter to accept heim joints. but if the difference isn't that great. I would hate to hack it up. thanks for your input.
Old Jun 11, 2015 | 09:34 AM
Metal Guru's Avatar
Metal Guru
Ooops, I was looking at the wrong picture. I think you'll get the same short shifting from both shifters but the FDM one will have higher effort. It would be worth a try.
What year is your car?
Old Jun 11, 2015 | 11:24 AM
Mondrian's Avatar
Mondrian
That's a nice car Metal guru - you got more pics up anywhere?
Old Jun 13, 2015 | 09:19 AM
Metal Guru's Avatar
Metal Guru
Thank you. Here's two more:
File Type: jpg
File Type: jpg
