Headlight screw removal.
I removed the screw on one of my headlights to check it.
Is supposed to so hard to remove? I was lucky I didn't strip it.
I can barely get it back in now. This normal, or did the PO use the wrong screw?
I'm thinking of finding a better replacement. Like a allen head or hex to make things easier.
I had a similar problem. My solution was just to push hard as I think the screw is too short to get to the threads without being forcefully pushed in. My dad was over for that fun experience and he said "with these old cars, if it ain't broke, don't fix it".
*Edit, I also changed the gasket around the ring, so that probably had something to do with it.
Yeah, mine was hard coming out and going back in. Really hard. I thought maybe the wrong screw is being used.
Or maybe I need to re-tap the threads where it's going in.
But, isn't that just like using a ratchet with a bit adapter on it?
I've done this, and yes it works pretty well on stuck phillips and also works great in hard to reach places.
An impact driver is also good on stuck screws.
The same as a ratchet with an adapter but smaller if you are sometimes in a tighter spot.
