Cleaning Engine Bay
Cleaning Engine Bay
Just looking at 911 PW yesterday re 964 buyers guide from last year where Phil's car is shown with the super clean engine bay.
What's the best way to clean the engine bay?
Same way as the rest of the car really.
I used Mer polish for the fan blades and any paintwork
Metal polish for any of the 'metal' bits that get that blemished/dull/corroded look
Black Plastic trim spray for the plastic bits (eg Son of a gun, Back to black etc)
I changed the fan belts. Nice black belts with clear white writing make it look much better - polished the pulleys whilst they were off.
Replace or clean the vent tubes to the distributor/lights
It's not too hard. Just think of it as a nice easy way to spend a couple of hours.
Main advice:
1. Take your time, be prepared to take bits off to clean them. It makes a much better job of the piece and allows access to other bits
2. Be prepared to get bored! Stop and continue another day
3. It's in the detail. Get every bit as clean as you can.
Hope this helps!
Main advice:
Hope this helps!
Re: Cleaning Engine Bay
Nothing to do with engines, but I've got a super-clean windscreen now, after using Turtle Wax windscreen polish. Gets rid of all those ground-on flies etc - well worth £4 at Halfords.
Cheers
Cheers
Originally posted by Bins
Where does one get "Son of a gun". I cant find it anywhere.
The only one I see is "back to black". Is it as good?
Cheers
Originally posted by delhi
can one use the a garden hose and just spray the engine down? I do that on my other cars. Haven't a problem.... yet. Yes I use Simple Green to get rid of grime.
Cheers
Two other cautions. Be careful around the sound pad, the one that sits above and behind the engine. It started to come apart after the Simple Green/garden hose treatment. Also, you may want to protect your air filter, especially if you have a drilled box or cone.
