R34 ABS Relay
R34 ABS Relay
Going the check list to see what's going on with my PDAS / ABS warning lights.
I took the relay out to check it, is it supposed to rattle when you shake it? Mine sounds like something is loose and ratting around in there.
It's a sheet of plastic that separates the metal casing from the solder joints on the PCB board. Just jump pin 30 and 87 on fuse panel to see if lights go away. If it does then the relay could be bad. The relays are notorious for broken solder joints and circuit boards with broken circuit tracks.
