964 Forum 1989-1994
MIA bolt!
Old Feb 16, 2015 | 08:17 AM
jmtama's Avatar
jmtama
Default MIA bolt!
I discovered that the bottom mounting bolt on the heater blower fan unit was missing today. Does anyone know the part number or exact size of this MIA bolt?
Old Feb 16, 2015 | 08:18 AM
jmtama's Avatar
jmtama
Forgot to mention its for a 1990 964 C2
Old Feb 16, 2015 | 08:33 AM
pi5tolpete's Avatar
pi5tolpete
M6x60. Both bolts are the same.
Old Feb 16, 2015 | 08:47 AM
jmtama's Avatar
jmtama
Thanks! Is the distance between threads all the same on this size bolt or do I need that piece of information as well?
Old Feb 16, 2015 | 08:56 AM
pi5tolpete's Avatar
pi5tolpete
Regular M6x1.0 thread 60mm long.
Old Feb 17, 2015 | 01:07 PM
LM964's Avatar
LM964
N 010 367 4 if you still need the part number too...
Old Feb 17, 2015 | 02:11 PM
C24FUN's Avatar
C24FUN
One reason these can be missing is that the threads in the holes they mount into are often stripped. It's a good idea to check this first. If you find that to be the case, it is possible to tap the threads in the hole a little deeper and use a bolt that is a little longer to maximize the number of threads the bolt connects with. You may need to custom fit and trim the end of the bolt to get it just right. Don't over tighten!
Jim G.
