Porsche 964 assembly
I recently purchased a new rear light assembly for my 964 and wondered if the rear corner lights also need breathing tubes, as the center piece.
Thank you.
Quinn
Thank you.
Quinn
The breathing tune comes from the engine compartment, thru the fitting on the unibody, to the center reflector. The center reflector then has its own fittings on each side that connect to the left and right light assemblies.
