Are you guys sure a stock 964 has 0 scrub radius? Asking because moving the wheel outward, via lower offset or spacer will make the scrub radius less negative.. If ET55 was 0, then ET50 will be +5mm (& ET52 = +3mm) so not likely.
Does Porsche define kingpin offset @ the wheel center or ground level? My hunch is that 0 offset is reported at wheel center height, which translates to a healthy negative value at the contact patch via the SAI. Anyone know kingpin angle for the narrow vs. wide 964's?
Steering wheel wasn't mentioned yet - changing to a smaller diameter usually helps by 1) increasing effort by reducing radius & 2) increasing effective gain (less hand movement for same change in wheel angle).
Careful with camber & toe, too much negative for either can make the steering overly 'darty'.
You are right I got it backward above, 7ET55 per Porsche has 0 scrub, 8ET52 has +3, positive scrub will require driver countersteer w/ uneven braking and will provide more feedback through the steering wheel. 8 ET58 has -3 automatically counter steers on uneven braking(prefered w/ ABS) and will also provide more feed back through the steering wheel.
The wider wheel provides more grip, an 8 will turn better than a 7 w/ the same tire
As bill rightly points out alignment is waaaay more important than components when it comes to how a 911 feels. You can have the best ever fandango shocks springs and bushes fitted but without alignment specs all "how it feels" chat is kinda irrelevant. Thankfully all 911s are designed in a way you can make them feel however you want but you need to find the right setup dude not the 'upgrade' parts sales dude.
So true. Ultimately going manual, but geometry is definitely the starting point.
Originally Posted by Atgani
Thanks for the "education". I'm currently on my 4th 964 RS, whilst having also owned three Mk 1 996 GT3's, a couple of 996 GT2's, a 996 GT RS, two 997 GT3's and a 993 RS.
I suspect I've had more alignments done on watercooled and aircooled Pork than you've had hot dinners ! But feel free to have a pop. Why don't you
And you are ...... ? ? The "dude" swapping his engine
Anyways, only my first sentence in my first post was directed to you and was very much said in jest, perhaps the smiley was missing but no malice was ever intended so apologies if it was received in that way.
Always liked you.
