speedline splitrims
#46
Wheels are all good.
Like the look, new tyres are good.
Last night went for a blip over the snake pass to Sheffield.
Ended up chasing a Bentley cab with a new a3 chasing me!
Great fun....
New tyres felt fine, but seemed to loose stability after a while.
Got home, checked pressures,
Rears on 44 psi
Fronts on 38psi
Way to much, I presume tyre fitter inflated them too much and with heat they increased
Wots best pressure for fast road use with ad08????
Great fun....
Rears on 44 psi
Fronts on 38psi
#47
Russ, 36 cold pressures all round should work with them. On a hot day when working the car hard they will go up a lot so you could try 34 at the rear and 35 at the front, cold, before you go for your run out.
#48
Looking really good Russ. Make it your own!
