Fuel injectors
Hi All,
I recently purchased some Bosch 36 lb fuel injectors. As some of you know I've got a 3.8 + stuff and when it was getting mapped by Wayne he mentioned that right at the top of rev range there was a brief lean period and would benefit from larger injectors.
My question is can I throw these straight in or do I need to consider electrical issues like impedance?
Throwing in these injectors will result in your engine running massively rich everywhere. Only way is a new remap. So long as the connector is the right type and they are high impedance injectors they will work.
http://users.erols.com/srweiss/tableifc.htm
Fixed the problem. The fuel pump was seized. It would jolt but not make a buzzing noise when powered. Replaced both the pump and the filter and now everything is fine.
