964 Forum 1989-1994
5th gear whine after replacing engine mounts?
Old Oct 4, 2019 | 01:52 AM
TxnBluDvl's Avatar
TxnBluDvl
Default 5th gear whine after replacing engine mounts?
I recently replaced my stock engine mounts with RS engine mounts. We also installed a Rothsport reinforced engine carrier mount at the same time.
Car has a brand new, rebuilt transmission that was installed about two years ago and did not exhibit this sound before. Car is a C2 and does not have an LSD.
I’m now noticing a whine in 5th gear and possibly a VERY faint whine in 4th gear. It’s not speed dependent.
Any thoughts as to what’s causing this?
Old Oct 4, 2019 | 02:18 PM
Spyerx's Avatar
Spyerx
Sure, you might be getting some additional NVH, did you change shifter too?
Old Oct 4, 2019 | 03:19 PM
TxnBluDvl's Avatar
TxnBluDvl
Thanks, @Spyerx. Car came with an RS lever. Was going to replace it with a golden rod and FD SSK next.
I skipped an aftermarket transmission mount since I’ve heard there are more NVH issues there.
Old Oct 4, 2019 | 06:33 PM
cjoenck's Avatar
cjoenck
So are your transmission mounts still the original? I just replaced mine and transmission noise is noticeable less with the new mounts. The old ones didn't look that bad but the rubber was gone.
Old Oct 4, 2019 | 11:55 PM
TxnBluDvl's Avatar
TxnBluDvl
Thanks, @cjoenck — I went through the old records, and I don’t see a record of replacement. If so, then they’re 29 years and 170k+ miles long in the tooth. Definitely a candidate for further inspection.
Old Oct 5, 2019 | 09:28 AM
chsu74's Avatar
chsu74
Just do the function first insert with the old transmission mount. Pair that with a new transmission mount if you want a stiffer and crisper shifting feel. Engine carrier and motor mounts are going to tighten the car up for sure.
