964 Forum 1989-1994
964 Tiptronic conversion to G50 6-speed manual Tranny
Old 07-21-2014, 05:32 AM
Dick964
Dick964's Avatar
Hi there,
As mentioned above : get the Porsche magazine of 2009. Good write up about what parts you need. Doesn't have to cost that much money..
But....
In the past I was also thinking about change my Tip to manual but in the end, after owning this 964 coupe with Tip for 7 years now, I find that the Tip in 'manual mode' is much quicker to shift then a manual and also very helpful to keep up with modern cars which more and more seems to have an automatic gearbox... (in Europe...).
Also on the Nordschleife the Tiptronic is not a problem at all (if in manual mode...) :-)
Grtz,
Dick964
Old 07-29-2014, 11:53 PM
legin21
4th Gear
legin21's Avatar
Thanks for the heads up!
Old 07-29-2014, 11:55 PM
legin21
4th Gear
legin21's Avatar
Originally Posted by Dick964
Hi there,
But....
Grtz,
Dick964
Dick964. Thanks. but i'm still a fan of the third peddle. its a little more fun! haha.
Old 12-21-2014, 05:18 PM
Michael D'Silva
Michael D'Silva's Avatar
any updates to this... have you progressed any further?
Old 12-21-2014, 11:59 PM
hockenheimr
hockenheimr's Avatar
Tip isn't bad at all....but I like to feel in control of the power so I am attempting the notorious conversion. Picked up a G50/05 and a bunch of other parts like flywheel, clutch, shifter....etc. Working on a parts list and some aftermarket parts. I heard the drive shafts need to be changed.....can anyone confirm this?
Old 12-22-2014, 01:22 AM
azander
azander's Avatar
You need manual C2 axles. The tip axles are too short.
Old 12-22-2014, 01:24 AM
azander
azander's Avatar
I've also had mine converted to a manual as well as a few others. A 6-speed is the same amount of work.
Old 12-22-2014, 09:28 AM
NoSub Dan
NoSub Dan's Avatar
I have a tip as well and after owning a manual 944, 2 manual boxsters and a manual 996 I'm finding I don't mind the automatic transmission. I know we're not supposed to drink coffee, talk on the phone or listen to music in our cars but i do all 3 and the tip makes it much easier. Plus, you can still get on it and have some fun with the tip in manual mode. You never miss a gear!
Old 12-22-2014, 11:15 PM
hockenheimr
Thanks, that's really good to know.
Old 03-08-2015, 08:21 AM
Michael D'Silva
What sort of money did it end up costing?
Did you do it or have a shop do it...
I spoke briefly to a major Porsche Indy here in Aus; they say they did it once, and will never take it on again... not very encouraging...
Old 03-08-2015, 05:25 PM
azander
azander's Avatar
Too much money. However I'd be hard pressed to find my car in the configuration I wanted.
A shop did it for me; it was their first. The conversion went well but they installed a bad part leading to a wild goose chase while under the assumption the problems were related to the conversion. Gotta be confident, experience helps.
Old 03-08-2015, 05:49 PM
hockenheimr
Apart from labor....which is going to be expensive.....and the transmission.....LA Dismantlers sells a kit for like $1,200.
Old 03-08-2015, 06:09 PM
azander
azander's Avatar
You have to factor in a new clutch/FW. The labor to install these goes a long way towards the conversion. I don't see going to all this effort to end with a worn out... basic clutch setup. LWFW FTW.
Quick Reply: 964 Tiptronic conversion to G50 6-speed manual Tranny
