cat bypass + cup pipe + gutted secondary?
OKay, I have a cat bypass and cup pipe. not installed yet. I know this combo sounds sweet from youtube clips.
I've also heard a local 964 owner with cat bypass / G pipe combo, also sounds sweet.
Since this isn't my daily driver. I want a little bit more noise. Not full on straight pipe loud. but slightly above either combo mentioned. I am thinking of gutting the secondary muffler.
what's your opinion on this? is this waste of time? Anyone has experience with gutting the internals of the secondary? I've only found 1 or two posts about this. that's with turbo car and otherwise stock. not much details
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
UPDATE: Possibly going with different configuration. Cat Bypass + Primary Bypass (with resonator) + G-pipe
It'd sound something like this I guess as without the internals it"ll be pretty much the same as a straight through pipe:
Rather loud for the street!
Sure. Straight thru will be way too loud to my liking too.
My friend's Evo 8 has this sport muffler that's been modified from stock piece. sounds very nice.
Then over at 993 forum. I must have seen a post about a company making sport mufflers using the stock pieces as well.
I would love to go with that approach if it's do-able on the 964 secondary muffler.
I've never heard it done but I think you should try it. With the amount of G-pipes installed it should be pretty simple to get another secondary to modify if yours is in good shape.
You would then be a pioneer as well!
Technical Guru
I have a cup pipe that replaces the primary. It sounds throatier, But I would like it a C- hair louder. That is why I have been hunting for a cat bypass pipe, and leave secondary. So, secondary on, cup pipe and cat bypass is my intent. I am guessing would be the perfect combo for me.
My assumption is that gutting some the material out. The muffler will resonate less? but not as extreme as have a G pipe?
with no scientific backing
Anyone want to sell me a muffler for cheap? I have all the tool needed to try this out. I can even take your cracked one.
what do you guys think of this configuration?
catbypass + cup pipe with resonator welded + g-pipe
Would it be still on the loud side? I've got everything except the resonator. Should I do it
No not at all. the goals is to achieve something that's not as loud as straight pipes. but slightly more sound than my current setup. cat bypass + cup pipe. I love the deep tone of what I have now.
ultimately, I want to save weight and space from the secondary as well. that thing is huge and weights a ton.
It could be worth a short to have that resonator welded into a cup pipe if you are willing to go with the trial and error method. Should be relatively cheap at a local muffler shop.
There was a time when I was trying to find an equally quiet but light muffler to replace the primary muffler, so I know kind of how you feel.
I bought my c2 with a cat, cup pipe and G pipe and its is way too loud and doesnt sound very nice at anything other than WOT. I recently sourced an OEM muffler to replace the G pipe. Hopefully this will fix things.
