'90 Targa project
#31
Attachment 842747 Attachment 842748 Attachment 842749 Here is mine after installing the motor from my wrecked 90 cab. I had to use much more parts than I thought from the cab, even wiring harness. I am finally stripping off every part I can today from cab before tub and title get picked up Saturday. I am hoping to get every last brake line off and the like that my patience allows. I have some small bit off this car if anybody needs things like I have offered before. The big ticket items are mostly gone. It does have a pretty new climate control unit I may sell. Good luck with project.
#32
I congratulate you on taking on your project, love seeing one of these brought back to life. I recently, 3 months ago, found a 90 C4 Targa while looking for a 92 or newer C2 coupe in not black or red. It had been well cared for to include a engine rebuild 10K miles ago to include the head gasket fix. Since getting it I have done a few simple things; first was to source some 9" rear D90's and new tires, next was to install PSS10's and lower the car, swapped the cassette holder for a tray, opened up the airbox, installed front splitter tabs. I have a short list of future fixes/upgrades but mostly just to drive it. The Targa top needs to be rebuilt, dry rot and loose headliner. Some combination of cat delete/primary bypass/G pipe and a chip.
Here are some photos of mine.
I look forward to watching your project unfold here.
#33
These are FVD, I also got a set for my '94 C2 as part of the Cult Werks group buy. Quality seems to be a push.
The top fit is still great, outer skin is a 7 but showing age, the headliner was sagging and dry rotted foam was blowing out small bits. I removed headliner and under laying foam to keep the foam stuff from getting in my eyes with window open. No leaks and wind seal still good, it will still need to be redone.
#34
Yeah - I know what you mean about the flying headliner bits. Where I picked up the air leak is in stretching the new top. I did the second one alone and fitting the new top is a 4 hand job - at least for me.
So I put the 5 cars back in our 3 car garage tonight and figured out the 1st step in the Targa project - clean out the garage.
The car as dropped in my garage seduces the unwary buyer into delusions of bargain found.
#35
So - car's off the ground. I figure - get the old (4 years?) fluids out before trying anything. First the oil. I open the tank and about 6 ounces of oil dribble out - bad sign. Where did all the oil go? Was the engine run dry? I move on to the crankcase and WOOSH - there's the lost oil - probably 9 quarts or more. First thing that came out was some water on the bottom. So I'm scratching my head. How did all the oil get into the engine? I'm playing with this thing - or it's playing with me. I'm also keeping an eye open for an engine. Next out - the old gas.
#36
Inside - I've found a rat's nest of wire left over from the previously installed and stolen sound system which might have been quite something in the 90's. I've started removing the excess, exercising caution not to yank out something wired to a necessary part of the original harness. Old "car phone" cradle is still there. Yes - they were once called car phones before they were made illegal while driving.
Under the engine cover - more missing. The blower motor and shroud are gone but wires dangle free searching for a place to be.
#37
Dying to hear if it runs. Hurry up!
Looks like with 964 and air cooled 911 prices gone crazy, people are digging into neglected targas. So much fun getting your hands on a neglected car and finding all the surprises!
