964 Forum 1989-1994
Oxygen sensor
Old 05-29-2014, 12:25 AM
B.Kish
B.Kish's Avatar
Default Oxygen sensor
I have a 93 with 27k miles and am doing some routine work. The O2 sensor has never been replaced. I have never gotten a CEL to indicate it's faulty. Should I consider replacing it? The car runs fine so I'm not sure. The car has seen some leaded fuel in the past and I know that can wreck a sensor after a while, but again, no CEL.
Thanks.
Old 05-29-2014, 12:37 AM
crg53
crg53's Avatar
I would test it to see if it's working probably. Search checking o2 sensor and you will find lots of info.
Old 05-29-2014, 03:56 PM
B.Kish
B.Kish's Avatar
Not a bad idea but a nice multimeter is more expensive than an O2 sensor.
Old 05-29-2014, 04:46 PM
jevvy964
jevvy964's Avatar
Dont buy an expensive one....el-cheapo mutimeters are the best. Drop them, kick them, leave them on for a month - they just dont seem to care and last for donkeys.
Old 05-29-2014, 06:37 PM
Goughary
Goughary's Avatar
I got my multimeter for under 10 dollars at harbor freight. Works great.
Old 05-30-2014, 12:29 AM
Silvertarga
Silvertarga's Avatar
HF gives them away, there is always a coupon for a free multimeter , I have a few and they work great, I also havbe a few others ("good" ones) and they dont get used as much as the HF freebie
Old 05-30-2014, 10:03 AM
B.Kish
B.Kish's Avatar
I have a cheap multimeter (non digital) but most resources online say the cheapos won't work. That's why I mentioned I'd have to get a new one.
Old 05-30-2014, 11:09 AM
964enthus
964enthus's Avatar
cheap,multimeter will definitely do
easy to test ,plenty of reference on this forum
i have just changed mine which was faulty(sudden increase in CO and HC and the last emissions test)
pain in the axxx to take the old o2 out (heat welded )
but retested yesterday : CO at 0.004 to 0.007 !!
on the old one ,one of theplatinum " electrodes " on the central zirconium post was slightly corrded
Quick Reply: Oxygen sensor
