Geo & Setup
#107
Well I hope we're able to continue this over a drink on one of the meets one day soon There are obviously some subtleties around this and I genuinely do want to understand the differing points of view.
#108
#109
#110
Mark (fuch) and I had another play with the geo on Monday night courtesy of mark's buddy's garage
I *wish* I had this lift at home !
Me spannering away on the tracking...
#113
The answer to that is a very loooooooong mind numbing story..... so to summarise,
(if I remember correctly)
The REAR is -1.1 camber with 10' toe in, each side
The FRONT is where everything started getting interesting. When the geo was originally done at JZM I was told they couldn't get sufficient caster on the front right, so had to wind back the front left to match it. This was evident by the positions of the caster adjusment cams. Mark's chap at the garage set the equipment up for us then left us to play so I have to trust/assume that was done correctly (no reason to doubt this).
However the issue now was, in relation to caster, this equipment was reading in complete contrast to that of JZM! The right was waaaay to far forward and the left was too far back. WTF!!! We scratched our heads a long time over this and decided to again set them equal :-S
A repeat visit is on the cards sometime soon purely focusing on the front of the car.
#114
Rob, Marcus at Wembley tyres has a very good set up for geo.
They did my 550, which had an issue and did a very good job.
unit 32
sapcote trading estate
high road NW10 2DJ
0208-459-6191
If you try it again yourself and still have some questions, maybe get a 3rd set of figures to help you figure out where you are.
unit 32
high road NW10 2DJ
0208-459-6191
#116
Bumping an older thread.
Everyone says "max caster" and "needs more caster", but is there a point of diminishing return when it comes to cranking on the caster? Is there a point where you can get too much? Should you start to ease off on your static negative camber as your caster setting increases?
I'd love to hear Steve Weiner and some of the other setup gurus thoughts on this.
#117
