964 headlight screw threads broken - hereīs a fix
I donīt know if this is a common problem, but some previous owner has ruined my 964īs front fender threads to install the headlight with one screw. Too much force used. As I donīt want to weld or solder anything to my car at this point, I created an easy fix. I used my Dremel mini-grinder to remove the old threads completely - so that all thatīs left is just a piece of metal with a hole through it. Some paint over the area where original threads were to prevent rust.
Then, I cutted a small piece of stainless sheetmetal, drilled a 5 mm hole, and silver-soldered a square-edged stainless nut to the sheetmetal. Just a bit more cutting and sanding and bending... and hereīs a result. Works very well.
The following 2 users liked this post by Stephen70:
kos11-12 (07-27-2022),
Metal Guru (07-29-2022)
Surely - except that if JB Weld would have been used, I would tighten the screw very, very carefully. If the nut gets loose when the headlight and screw is attached, removal of headlight can be a real nightmare.
Nice!
Tore
Tore
No, original screw is just long enough. I also had a rivet nut in mind, anyway I had no luck to locate one - and I had to get it done as driving season is about to start here in Scandinavia shortly.
Always nice to see other solutions to a problem :-)
I used a rivet version.....my lazy way to fix it.....
But your solution can be useful in other places that are in a enviroment with salt and mud
