I spent £12 on some E-Tech spray and didn't have high hopes. My rear lights and reflector were pink and faded. An hour or two later and the change is dramatic (more dramatic in the flesh). Definitely recommended.
Wow, I'll have to give that a try. Seems much easier than film. Mine are cracked pretty severely too. It's hard to tell in your before photo, but are yours cracked too, or just faded? Also, what color tint is it exactly?
Yep mine are cracked too but seem less so after using the spray.
Here's what I did:
1. Took off lenses.
2. Briefly gently sanded with 1500 wet and dry (it didn't say to do that but I thought I'd get a better result).
3. Masked off around the removed lenses and then sprayed.
The crack in my reflector is so bad that I will need a new one at some point.
