Heater Duct Bypass Quick Question
#33
Hi ,
I Just refitted my distributor and took the opportunity to connect the rear lights vent tube to the distributor tube, it is from a fuel connector 1/4 " , it saves to drill a hole in the bypass
![Name: image-3037658326.jpg
Size: 432.5 KB](https://rennlist.com/forums/attachments/964-forum/817951d1395573400-heater-duct-bypass-quick-question-image-3037658326.jpg)
#34
That's a good way of doing it, will probably do it a similar wary if the tail light vent becomes an issue. When I put my bypass on I was very limited on time and spare parts.
#36
#37
I have the same pipe as you, and it just lined up great. I worked it in from the bottom first and then attached it to the top shroud. Maybe try loosening up the fan shroud to allow a little more maneuverability.
#38
Put a bit of grease at the bottom , around the rubber & the pipe, fit the bottom first, then the top, it may in some cases not fit perfectly at the top but once you screw in the clamp it won't move,
