964 Forum 1989-1994
Heater Duct Bypass Quick Question
Old 03-16-2014, 12:09 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by NJ964
Also, where are you guys finding the blower motors for less than $200. Other than second hand, the lowest I saw was twice that. Pelican is selling them for almost $500.
HERE is one place and there are lots of others.
high flow air filter to clean up the other side.
What are your expectations? If it's for anything other than aesthetics you are wasting your money.
Old 03-16-2014, 12:54 PM
NJ964
NJ964's Avatar
Ok, I see just the motor is that price and I guess I was looking up the whole assembly. Either way, still happy with the bypass pipe.
I'd obviously get the air intake for performance reasons, but an added bonus would be to clean up that side of the engine bay. The EVO HighFlow kit looks pretty good, but haven't really don't any research into intakes yet.
Old 03-16-2014, 02:10 PM
crg53
crg53's Avatar
The picture with the 2 jumper wires is NOT the way to go, thats an old thread. You run a 7.5 amp fused wire from the + side of the coil to post #87 in the relay socket. That is by far the best way to go. Anto 1150 was the one who came up with that solution, and has worked perfectly for me, with no drain issues.
Old 03-16-2014, 02:27 PM
crg53
crg53's Avatar
My questions now are, where is this relay located and did you need to change the resistor. It seems like some people did and some didn't with about the same success. Since, the blower motor is gone I don't see why that resistor is even a factor and it seems like just jumping the relay would work fine.
https://rennlist.com/forums/964-foru...er-bypass.html
You disconnect the heat sensor and the resistor, I el taped off the ends and zip tied them out of the way. I also pulled the 30 amp fuse for the heater blower motor, so no power to the wires.
As far as the relay, look in the picture above, its right next to the coils.
Old 03-16-2014, 03:40 PM
kos11-12
kos11-12's Avatar
exactly the way I wired it, works find ..!
Old 03-17-2014, 03:26 AM
NJ964
NJ964's Avatar
Thanks, I was only able to be with the car for the weekend, so it will have to be a job for another day. It seems pretty simple and straight forward though.
Crg53, what was the issue with the jumper method that you first used?
Old 03-17-2014, 02:46 PM
swftiii
swftiii's Avatar
I have looked at doing this before, but all the disparate information did not make the DIY very clear. crg53 - it seems to be pretty easy with your instructions. NJ964 - please post some final pictures and the steps you took to get this install done so the HVAC fans still work as needed.
Thanks for taking this project on....
-Skip
Old 03-17-2014, 03:37 PM
crg53
crg53's Avatar
I didn't have any issues, but others have reported battery drain with the double jumper wires. My car is always on a battery tender when parked, but if you leave it sitting for a while without you may run into problems.
Old 03-17-2014, 06:12 PM
ThomasC2
ThomasC2's Avatar
I think the drain is depending of MY. I have a -92 and have had the double cable set up for many years now and I haven't noticed any draining problems. In earlier threads it seems this is more crucial on earlier cars (if it is a real problem).
A tip is to not touch the CCU until you're done with the whole setup. If you do you'll probably activate error codes that shuts down the fans etc, and you can' reset them without a scantool/Hammer.
Thomas
Old 03-17-2014, 08:43 PM
hepkat63
hepkat63's Avatar
yep... a proper (with pictures) DIY is screaming out for this i think !
Old 03-17-2014, 08:47 PM
NJ964
NJ964's Avatar
Well I'll have a couple months before I get back home to where the car is, in the mean time I will do more research into wiring solutions. Once I get back and finish everything up, I will take some detailed pictures and do a proper write up.
Thanks for the help,
James
Old 03-18-2014, 12:58 PM
NJ964
NJ964's Avatar
If you go to page 2 of this thread, he has a pretty decent write up on the relay bypass. Basically the same way crg did it but he wired up a new relay (old one melted) and changed the 7.5A fuse in the box instead of in the wire.
http://eurostyle-tuning.com/forum/sh...4-Build-Thread
As a side note, this thread has a lot of other interesting write ups worth taking a look at.
Old 03-21-2014, 08:02 AM
GTi451
GTi451's Avatar
Appreciate you adding that link here. This is a piece I've been tossing around for a while now too.
Old 03-21-2014, 11:08 AM
swftiii
swftiii's Avatar
NJ964 - that would be great and Thank You!
Old 03-22-2014, 03:01 PM
EdwinL
EdwinL's Avatar
Default 964 RS Heater Bypass Pipe
Here's a picture of my RS with the bypass pipe.
Quick Reply: Heater Duct Bypass Quick Question
