More Idling Gremlins....Please help!
I have a 1990 C4 Cab 964 3.6 L with lightweight flywheel
When I got it, I had serious problems with the car just dying on me randomly while idling.
I have done the following.
1. Replaced both coils
2. Full tune up with new spark plugs (Top and bottom)
3. New Distributor rotors
4. Changed the chip in the computer to Steve Wong chip for LWF
After doing all of this I had the same problem. I then replaced the ISV. The problem has stopped. The car no longer dies on idling. BUT!!!!!
It hunts for idle. When Im in stop and go traffic. I lurge in first gear and push clutch and release the car out of gear. The RPM's drop to 200, then 1400, and then in a 1.5 seconds settle at 800 RPM's.
I have pulled the throttle cable and the microswitch does click as soon as throttle cable is engaged.
As a side note, which may help....On strong acceleration the car hesitates for a microsecond without change in the RPM's
WHAT NEXT?? O2 sensor???
Thanks,
Raghu
Thanks,
Raghu
I dont have the LWF, but have had idle problems. I found the following thread usefull. I'll take the car for a good drive this weekend to see if my work has paid off. If it doesnt it'll be going on the Bosch Hammer for the adaptation.
Chris
http://forums.pelicanparts.com/porsc...-gremlins.html
Chris
Raghu,
I've been having some idle issues which have recently remedied after I discovered a leaky hose on my crank case breather. After tightening the clip on the hose the issues have all but gone. I only realized I had a leak when I developed an oil leak as a result of filling my oil reservoir up otherwise it would not have been apparent.
Dave
Dave
Also worth having a look at the connections of the main battery earth strap, especially the end that attached to the body. They can corrode badly and start to cause all sorts of miscellaneous problems so cleaning it up is a quick and easy job that's well worth doing anyway.
