964 Forum 1989-1994
Torque specs- reduce w/use of anti-seize?
Old 02-24-2014, 02:02 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by Vandit
I put Permatex copper anti-seize on stuff and torque to spec.
You obviously have a death-wish.
Old 02-24-2014, 03:19 PM
YaHoo!
YaHoo!'s Avatar
Vandit-
I think you need to go back and redo your projects using the right stuff
Old 02-24-2014, 03:22 PM
YaHoo!
YaHoo!'s Avatar
They are definitely 100% not the same. Optimoly HT is copper colored and NR (Olistamoly) is this black goopy stuff that sticks to everything and is impossible to remove. You would never use NR on your exhaust fasteners or your wheel studs... The names next to the part numbers in the list all link to the spec sheets.
This is really helpful, thanks Jason!
Should I throw out the non-contentious question on whether to apply anti-seize to spark plugs and wheel studs now
Old 02-24-2014, 04:05 PM
dutchcrunch
dutchcrunch's Avatar
Default ht optimoly
I think Porsche has a label glitch cause I can confirm that p/n 000 043 004 00 is copper grease from sunset 2 month ago but on tube it says NR_ optimoly paste. so
Old 02-24-2014, 04:07 PM
kos11-12
kos11-12's Avatar
Hey Jordan,
the G50 looks great, and the Norton, I race a Ducati 350 narow case 65 and a BMW 980cc 76 in endurance races,
glad to see a classic bike rider on this forum
Old 02-24-2014, 04:37 PM
JasonAndreas
Technical Guru
I have a tube of Olista Longtime 3EP that also says NR Optimoly... German part numbers are preceded with Nr? so I wonder if they print NR Optimoly on the side of every tube? That would explain why the tubes of OlistaMoly2 were labeled as Optimol-NR even when OlistaMoly2 was superceded to the higher temperature OptiTemp-PU35.
Quick Reply: Torque specs- reduce w/use of anti-seize?
