Need a Fan Stud
Years ago when I had my fan out I broke one of the mounting studs that poke out of the fan hub. Porsche doesn't sell these as a separate part (as far as I know) so I just cut the head off a bolt, ground it down to the right length and set it in with some Loctite.
I now have the fan out again for some cleanup and seeing that ground down bolt is just annoying me. I would like to find the proper replacement part (3.8 cm with Allen key socket in the long thread end).
If any of you have any of these pins/studs lying around from a failed fan I would appreciate it if you would let me know.
Cheers!
Jim G.
Cheers!
Jim G.
