Front Blower Fans: repair or replace?
My front blower fans have been squealing for a while at low speed and for the first time must have created enough of a load that it blew the #1 Fuse. It looks like I need to replace them but before I do has anyone ever repaired them? I suspect the bearings need some grease after 20 years. Is this possible or is it just better / easier to replace? If I replace is there a good source or is the only real option a 964 part / price?
Thanks for the suggestions.
Peter
Peter
After some research it would seem the right side fan is shared with a Mercedes 190 with a mod to swap the fan it will work. The left fan has a slightly different winding shape but with a little work to the housing the right side fan can be used. More info on bearing change etc on this link below.
https://rennlist.com/forums/964-foru...rt-number.html
