The silly little question thread ...
#1096
Thanks guys. I have the tool kit with the proper tools for the job, but to me the tool that holds the shaft could be more snug. I have a 3/8 drive socket that is a more perfect fit but no space to get socket on. Knowing me I'l round the alternator shaft with the oem tool.
On another silly note, I believe its mentioned that it should be a specific torque, but how did they account for that with the oem tools?
#1098
#1099
Do the earlier 911 rear windows fit the 964 if we reuse the 964 window rubber?
I currently have a hole for a non existent wiper and would like to do away with it, the 3rd brake light "square" and heater lines too if possible.
#1100
There are a few options. without the 3rd brake light square and the wiper hole. Mine has a plug in it right now.
IF you go the plug route, this is a really nice piece
http://www.ebay.com/itm/Porsche-911-...wAAOSw9N1VoV6T
#1101
just locate the RS or ROW glass.
The RS glass would certainly be a good solution. My thought about the earlier glass is that it would be MUCH more economical to buy a good used rear window from the local Porsche dismantler from an earlier car.
#1102
Advise please on new carpet kit. I have deleted the center console of my 964 Cab Triptronic and also cleaning up the rest of the tunnel to be more like in the old days. Is there a standard 911 kit I can order ? OR do I need to be special order 964 "dont cut up my carpet on tunnel" ! I was looking at Lakewells kits unless anybody has a better suggestion in Europe Thx
#1103
How loud is your coupe relative to this? How about with your soft-top up?
I know where some of the noise is coming from (the window seals aren't sitting 100%) but I'm also somewhat curious as to what the best (coupe) sound insulation is like on our cars at 85 under heavy load (merging).
#1108
#1109
https://www.cult-werk.com/k2/angebot...tzt-zuschlagen
#1110
Going to prep for rebuilding my pedal box soon. Lately the clutch has not been coming back very smooth which is mainly a problem for first gear when letting it out slow. I had shot some WD40 into that busing space where it rotates and that helped a bit.
Question is, will these 993 bronze bushings fit?
http://www.autoatlanta.com/Porsche-P...042349800.html
