The silly little question thread ...
#751
So yesterday my spoiler decided to no longer move. When you first turn the ignition, the spoiler light indicates, and then turns off as usual but the wing cannot be put up by the switch or by driving. I checked the fuse and pulled the cover off the motor to check for debris but didn't find any.
Any ideas?
Any ideas?
When mine did this it was the bearing in the transmission (Porsche used an unsealed bearing which after time rusts out) . I waited too long and the motor burned out. At no time did the fuse blow..The bearing can be replaced, quite a few tutorials on it around the web
#752
IHI KING!
first time going this far with any car...most difficult DIY job I've finished was replacing the front bumper...anyways, my oil pressure gauge needle was acting funny, so I have gotten to the sender...but the damn thing won't pull out...how do I get the sender manifold out...just pull or lift with a flat head screwdriver?...impossible to get a 24mm wrench in there to turn...thanks
#753
Disconnect the wires and pull the unit out with your hand. Clean the area first so nothing yukky falls into your oil reservoir. It's held in my a rubber 0-ring.......... Replace this too, its about $1!
The unit can then be held in a vice while you undo the nut.
Mark.
90C2
Mark.
90C2
#754
Disconnect the spoiler transmission (attached to the motor) and see if the spoiler will move. Also while the transmission is disconnected from the motor see if the manual operating switch activates the motor
Between this and the spoiler top cracking on me, I am inclined to put a fixed wing on it...
#755
I was kind of dreading having to do it, but it turned out easier than I thought. I didn't even touch the intake stacks, just removed the AFM and reached around. Unless you have seepage around the housing (meaning O-ring is leaking), I would just go this route. I bought the cheapest crowfoot I could find, believe it was from SummitRacing (no affiliation), and it worked like a charm. Just make sure to have it sit around the sensor well enough so you don't strip anything.
#756
my car is lowered and i just have 225/45/17's on cup i's in the front but on full compression something is cutting into my tire - i believe someone wrote about a fix - perhaps removing one of the screws that hold the liner in? might just be the inner fender and i need to roll it.
#757
there is a steering stop upgrade, if not.
#759
Don't quote me on this, but I believe there is a fuse for it in the fuse box in the engine bay.
#760
I just purchased a used cup pipe but it didn't come with the two straps...can I use the factory straps from the stock primary mufflers for the cup pipes?
#762
Great, Im going to have to replace the other side as well to equal the weight savings
Related: The factory manual calls for 339 ft-lb of force to tighten the nut. My largest torque wrench goes to 250 ft-lb. Not wanting to spend $500 for 3/4 inch heavy duty torque wrench I turned to math calculations: http://hyperphysics.phy-astr.gsu.edu/hbase/torq2.html - Using my weight, gravity and 2 feet extension. The problem with that is the new design of the nut - it doesn't have enough surface to support the socket so I can freely stand on the extension.
Or I could just use torque multiplier.
Any help much appreciated.
Thanks!
Andrew
Thanks!
Andrew
#765
