The silly little question thread ...
#736
Ok body-shop folks: I bought a new rubber "smile" and this is what I've got now that I've tightened all the nuts and bolts .
Anyway, is the smile supposed to be above the fender and below the frunk as shown below? You can see the "bubbling" up of part of the smile in the second picture...
from inspecting other 964s...I adjusted my front end of the frunk to sit snug onto the rubber weather strip so to prevent water seepage...so my frunk is sitting slightly below the bumper but flush with the fenders....you can raise/adjust the bumper with the bolts holding the bumper from inside the cargo bay (near the latch)...
in your picture, the drivers side frunk line looks off from the fender...I had the same issue when receiving the car...I found it easiest to adjust the frunk by loosening the 4 allen bolts (2 on each side) at the rear ends...closing the frunk but not locking the latch.....in this position, I gently repositioned the frunk so that all grooves looked even around its perimeter...then half opened the frunk without causing any shifting and re-tightened the bolts...
#737
Aligning the smile is a time consuming job done best on a lift at eye level. It takes a lot of back and forth and readjusting. I found that it worked best once I had the smile installed in the support plates on either side to gradually tighten from the middle and work my way out pulling and stretching as you go. I don't tighten any of the screws until I get it close and then go back and start from the center again securing the screws one at a time and checking the fit. Sometimes if it is difficult using a hair dryer to soften the plastic to lay flat helps but don't over heat.
#738
Great feedback guys.
LuckyJ - Did adjusting the frunk not cause the front part to bubble up more? I see the logic of putting more weight on the smile via the frunk, but I'm just concerned that it's weight in the wrong place that will cause it to push up more.
Anthony - Ha, I'm finding that out now When I removed my old smile from my old bumper, there were two rivets that were about 1.5' from the center line and fit into pre-made holes in the bumper. My new bumper has the same holes which makes me think that perhaps the solution is riveting? I'm also only finding 3x screws per side that attach the bumper to the fender, there don't appear to be any other screws that sandwich the smile between the bumper and the body.
#739
I have done 5 of these in the past year and they are usually a PITA and no two react the same to the adjustments.
#740
Thanks Anthony, I undid the 4 screws that hold the metal plate that slides into the back of the smile and adjusted (about 5x) until it was right. Very helpful and saved me from pulling the whole bumper off and putting it back on.
Front bumper looks great. Below was a great help.
#741
the riveted plates hold down the rubber smile...like cobalt mentions...it is a real PIA to slide the underside of the smile grooves into these plates...I used lubricant and many attempts...gotta be real patient but it eventually fit...
#742
Glad I was of some help.
#743
should I be in a rush to fix this torn rubber? Its torn on both the blower side and the shroud side. Can just the rubber be replaced or do I need to replace the parts? Do you guys have part numbers or names for these parts? Thanks!
#744
You need part#96410640302 (Air Duct) and make sure you get the 964 part and not the 993 one or else it may not fit correctly. It is a simple removal/install... Take the blower out by disconnecting 2 wires and removing (2) 10mm bolts, then loosen the (3) 10mm bolts holding the air duct, slide the old one out, put the new one in, tighten the previously loosened (3) 10mm bolts, reinstall the blower, reconnect the wires, and you're done.
#745
964 106 402 06 or 964 106 403 02
#746
I bought 6 cluster bulbs from Pelican (spares are always good). Disassembled the cluster bulbs to the bare element and 2 wires. Un-soldered the old bulbs and re-soldered the new ones. A little fiddly, but worked a treat. All of my center console bulbs were out, now she has a warm glow when driving at night.
#747
#749
So yesterday my spoiler decided to no longer move. When you first turn the ignition, the spoiler light indicates, and then turns off as usual but the wing cannot be put up by the switch or by driving. I checked the fuse and pulled the cover off the motor to check for debris but didn't find any.
Any ideas?
Any ideas?
#750
oil pressure sender
first time going this far with any car...most difficult DIY job I've finished was replacing the front bumper...anyways, my oil pressure gauge needle was acting funny, so I have gotten to the sender...but the damn thing won't pull out...how do I get the sender manifold out...just pull or lift with a flat head screwdriver?...impossible to get a 24mm wrench in there to turn...thanks
