964 Forum 1989-1994
964 TT build - Need help with gearbox choice/ratios
Old 01-06-2017, 11:57 AM
  #661
964TT
964TT's Avatar
haha NBoost
Did anybody ever look into dropping the seat a bit lower? Always thought it to be a bit high. Not too close to the roof, I have a non sunroof car, but just high in the seat.
My original Speedster/RS seats (with springy bottom) won't drop any lower so since my car is at the body shop I asked them to look into this and perhaps lower the mount on the body a bit.
This seems to be the only solution.
I'll get some photos.
Anybody ever done this?
Old 01-06-2017, 02:43 PM
  #662
NineMeister
NineMeister's Avatar
Originally Posted by 964TT
It is all custom... Heads, rods, pistons, cams, rockers.
But the deck height is not correct as it is, so it needs to be corrected some way.
Unless you run the RSR cylinder seals (easy conversion with the engine apart) the best solution is to have Capricorn manufacture you some new cylinders which are 1.0mm longer than standard. I would not run shims with O-rings at the bottom of the cylinders. The alternative is to run soft stainless steel shim rings between the cylinders and the heads - like the 965 3.3 turbo engines - however this will not allow you to also run a Le Mans sealing ring.
You are correct that deck height is important. In fact I would go as far as saying that it is one of the most important measurements in the engine because it determines the squish performance of the combustion space. Too close and the piston could kiss the head when it stretches under load and furthermore the squish velocity increases, speeding up the burn at a risk of pre-ignition and partial combustion. Too wide and the squish gap is ineffective, creating hot spots in the chamber or worst case inducing detonation. 1.0mm is a safe standard 0.8mm is perfect provided you have calculated the rod stretch correctly at the maximum speed of the engine. If you cannot do the maths, work out the piston G at peak rpm, hang the equivalent weight on the end of the conrod and measure by how much it stretches. You will need around 3 tonnes for a 600g piston at circa 5000G.
Old 01-06-2017, 02:50 PM
  #663
NineMeister
haha NBoost
Standard seat mounting on right.
Lowered seat mountings on left.
Old 01-09-2017, 05:09 AM
  #664
964TT
964TT's Avatar
Excellent, thanks for those photos Colin!
As far as the shimming goes I leave that up to the builder now, he has the engine. So whatever he decided I am fine with, he has experience and I trust him to do well.
Old 01-09-2017, 08:04 AM
  #665
964TT
964TT's Avatar
And here's the finished work of the front end rebuild.
This is going to be so much better for cooling the intercooler and for the oil coolers as well.
Old 01-09-2017, 08:34 AM
  #666
Undutched
Undutched's Avatar
Ohh heck yes Thomas!!! could you send me the contact info for the chassis builder?
Old 01-09-2017, 09:45 AM
  #667
964TT
964TT's Avatar
Sure, no problem!
Old 01-17-2017, 09:20 AM
  #668
964TT
964TT's Avatar
New situation of the front end. Excellent how the oil coolers are placed and the radiator for the intercooler will get great flow.
Very happy with the result, just need to reorganize the frunk... Not much space left. Pump for power steering still needs to get connected.
Old 02-14-2017, 05:14 PM
  #669
964TT
964TT's Avatar
Waiting eagerly for the engine, should be done in a couple of weeks. Edelweiss who designed the engine works closely with Mezger Werks where the engine is now. They are getting the whole thing measured, adjusted and back together.
Old 03-06-2017, 07:43 AM
  #670
964TT
964TT's Avatar
Excellent, looks like I'll be picking up my engine very soon. Perhaps early next week!
We are also installing a scavenge pump for the turbos, with a delay so it runs a bit longer when you turn off the engine.
Cant wait to get driving again, very excited!
Old 03-20-2017, 09:53 AM
  #671
Cazzo Super Velo
Cazzo Super Velo's Avatar
Any progress made?
Weather is still crap, but soon the trackday season will start again...
Old 03-20-2017, 11:10 AM
  #672
964TT
964TT's Avatar
Yes, already missing some track days...
Luckily the engine is done tomorrow so I'll pick it up end of the week in Germany.
Then it's just a matter of putting the engine back in.
Readjust the ECU and running in the engine is the only thing left to do then...
Old 03-20-2017, 12:46 PM
  #673
Cazzo Super Velo
I know how you must be feeling.
We are missing the first race of the Squadra Italia on april 8th because of too much work and too little time...
(and my brother crashing the Alfa at Spa in november, which meant that we could start preparing only one month ago when it came back from the body shop)
Old 03-20-2017, 04:25 PM
  #674
koenig_roland
koenig_roland's Avatar
who did the engine in germany finally?
Old 03-20-2017, 05:19 PM
  #675
964TT
964TT's Avatar
Matthias Höing from Mezgerwerk in Hamburg build it and Dirk in Essen designed it. They collaborated on finishing it up.
In the end it all worked out fine, can't wait to get engine back.
Quick Reply: 964 TT build - Need help with gearbox choice/ratios
