Carrera 4 Leichtbau - replica
1 Post
Jack, just get your car to look like this. You car is a nice original colour (that u plan to refresh), u have the CUP 1's. Just put a black carpet set and dash in when putting it back together and will look great.
http://www.germansportscars.net/GB/s...11-964-rs/329/
Plus u will have a chance of getting your money back if u need to sell.
just my 2 cents.
just my 2 cents.
just my 2 cents.
just my 2 cents.
the 9" wide rims are available, they were fitted to some 944 Turbo and the 928 GT. I use them along with 7" fronts on Shrek. The Mg legend has been debunked already.
The manual diff locks are simply master cylinders replacing the hydraulic command of both diffs. Bigger issue I see is the difff computer taking offense at being disconnected and throwing a permanent alarm.
Has it?
Maxted Page arent the type of dealer to give out false info
http://www.maxted-page.com/resourcel...f75ccb7dc7.pdf
Eithere here or on Pelican. Everyone talks about them, yet no one has been able to show us a wheel up close, or a part number. A Mg wheel has to be slightly different, mostly in thickness to be useable at all. Different enough to be readily visible.
I have asked, on forums and privately, to several people who have been in contact with these cars to provide details and pictures of these wheels, in the last few years. Not one answer.
Every available picture of these rims shows a rim that is an exact duplicate of the series wheel, in thickness, details, everything.
More like unicorn sh*t or the yeti. A lot of talk, but zero proof.
Edit: See here:
https://rennlist.com/forums/964-foru...ghtweight.html
A clip-on weight on a Mg rim? Even the factory is not that stupid...
Edit: See here:
Do Carrera RS mags look any different to alloys?
Maybe if you get down and inspect them (and obvioulsy the part numbers) but to look at in pics or a walk aroound the car etc they look no different
I have no dea whether the factory used mag D90's or not, but its hardly unlikely on a run of just over 20 cars, when they used it on the producton RS
I have seen some C4 RSL's advertised as having alloys, and others as mag wheels, as per the Maxted Page car. Maybe both exist? I would have thought a company like they would check the provence and only advertise what they have in front of them, not what may or may not be
There are previou sthreads on here where people who have been in contact with some of them, have stated they have mag wheels as well
Lemme expand:
The Cup 1 Mg wheels look a lot like the alloy versions. That is because the Cup 1 by design has no sharp angles, no edge lip, and a rather roundish design.
There are some rules learned the hard way with Mg rims for street use. They hate water, and salt with a passion. They will corrode at warp speed if the paint is compromised. For the same volume, dictated by design, a Mg rim is not as strong as an aluminum rim. Sharp angles wil act as stress risers.
Now the D90 rim is a nightmare to make in Mg. It has sharp angles, a thin design, and a lip to which the factory did put clip-on weight. And it is very light.
So to make a Mg rim with the exact same design is nonsense. The first moron that clips on a balancing weight is promoting the corrosion and failure of the rim, at its most exposed spot. Since most of these cars have no miles, it is reasonable to assume the weights were factory-fitted. Ergo.
Digression: the factory did make Mg Cup rims, for the 944 Turbo Cup, in 8&9X16 in the phone dial design. I had about 20 of these. While they look exactly like the alloy version *on pictures* they are in fact very different. Thicker everywhere, particularly in the lip area. They made sveral hundreds of them (over thousand?). They bend at the sight of a pothole.
I would love to see a direct photographic comparison of a std alloy and a Mg Cup 1 wheel off a '92 RS.
And I still challenge anyone to show me a Mg D90 rim. Seriously.
Maxted? Car salespeople. Enough said.
I understand your project as I aslo own a C4, at the end of the day if your strip it is for maximum performance your certainly don't want to put heavy wheels as this would also spoil the handling,
I would just go for some details, like the spoiler, oil flap, black headlight rims, total striped interior with race windows, you would already have a real challenge to make it weight 1080 kg
Really?
Jamie
I am also curious to see those wheels. I agree that just casting them in the same cast as the aluminum wheels, is hardly an option.
That being said, I came across these wheels on an early 964 C4 at the Porsche museum. Notice that they are not 944 Turbo S / 928 Club Sport wheels.
Weights are sticky-type, no clip-ons.
