T-OBD Scantool can't connect to ABS module
My T-OBD Scantool is a real "jewel" in my book considering what it does and what it costs. Once upon a time I owned a Bosch "Hammer", but that is now long gone. It was a great and uselful tool, but Tore's interface and the Scantool software does much of the same. I have encountered one problem, however, and wonder if anyone else has done so too. When I attempt to connect to the ABS module on my '92 C2, the tool simply refuses to connect. It tries, but never manages to do so. Any thoughts??
Technical Guru
The C2 ABS controller has no built-in method for onboard diagnostics. There is an LED tester from Bosch but that just makes it a little easier to directly check the sensor values. You can do the same with a multimeter and oscilloscope.
Thanks, guys. I have no issues with my ABS at present, but I just decided to check it for the heck of it yesterday since I had my laptop in hand. Now that I know I cannot connect to it with Scantool, I'll just be happy knowing that it all appears to be working. Thanks again for the good information you have provided me.
Cheers,
Tore
When I first used my scantool under win 7 I´m shure to have had an entry about an "unknown ABS fault"
After switching to win 8 I had to use a VMware player. Since then I´m not able to connect to ABS with my C2.
Very interesting, though I don't think applies to my situation. My laptop with the Scantool software is still running Vista. I believe all other respondents to my post have indicated that the current Scantool software will not connect to the ABS module on a US Carrera 2
