Another 'Lift' System ~ QuickJack
Came across this on Pelican, relatively new still. I love how portable it is, considering I don't have the space for a scissor jack or any other lift system in my Garage setting.
The Flaw, price tag of ~ 1000$ and currently the lifting capacity isn't 'too high'.
But in the future weight issues would probably be addressed.
Thoughts?
Thread on Pelican: http://forums.pelicanparts.com/porsc...911-914-a.html
Thoughts?
Did you look at the Maxjax-I thought the same as you -no room- but I bought the MaxJax and every so often my garage becomes a workshop and then reverts back to a garage.
I could not be happier and other than being an owner of one no affilation
That's a friend's car in that video. He's getting probably 15 of them for us locally, fully tested to his satisfaction.
Understand this is a portable unit intended for trackside use. The retail price is a rounding error when you consider how convenient it will be for a crew, weekend free helper or paid pro.
I bought this about 5 years ago and have been very happy with it:
http://www.gregsmithequipment.com/At...e-Midrise-Lift
It kind of works.. I have one. It works best if you run the ramps backwards due to the lift points on the 964. In the standard position the lift points can't get far enough back to reach the hard pads near the oil thermostat. That means the front 'hinge' of the lift is right against the back of the front tire, and the front lift point isn't in an optimal position. Like I said it works, but not a perfect fit. You CAN use the lifts sideways, but I haven't tried it.
Also FWIW, my power unit and cylinders failed at 13 months of a 1 year warranty and the company stood by their equipment and replaced everything with a smile.
I bought this about 5 years ago and have been very happy with it: http://www.gregsmithequipment.com/At...e-Midrise-Lift
Yeah, apparently the newer version, the SLX, has been redesigned specifically due to input from Porsche owners - so they will fit 993's, 964's, etc.
Would love to hear any comments, good or bad, from people who have used one.
I prefer the Quickjack vs the other lifts because I like having access to the middle of the car.
