964 Forum 1989-1994
correct tire pressure for 17" tires?
Old Sep 25, 2013 | 01:54 PM
pi5tolpete's Avatar
pi5tolpete
Default correct tire pressure for 17" tires?
I have just swapped out my 16" cup wheels on my 91 cab for a set of 993 Targa Speedline wheels, 7-17 on the from and 9-17 on the rear.
The tires are continental sport contact2 tires at 205-50-17 front and 255-40-17 rear. MY OEM wheels and car pressure stamp says 36 psi front and 44 psi rear.
What pressure do I run with the 17" wider tires?
Old Sep 25, 2013 | 01:59 PM
crg53's Avatar
crg53
The general consensus is 36 psi all around for every day driving. I did some experimenting and settled for 35 psi.
Old Sep 25, 2013 | 02:00 PM
pi5tolpete's Avatar
pi5tolpete
Ok, seems to jive with what the PO thought it should be.
Thanks!
Old Sep 25, 2013 | 05:07 PM
swftiii's Avatar
swftiii
Porsche had defined it to be 36 with a TSB or some bulletin at some point.
-Skip
Old Sep 25, 2013 | 06:07 PM
BGLeduc's Avatar
BGLeduc
TSB #4440
The copy I have is dated 1/23/2004
Brian
Old Sep 26, 2013 | 09:43 AM
92C2Targa#119's Avatar
92C2Targa#119
Default 17" Tire Pressure
Peter:
Great to hear 35 lbs is correct. How do they look on? Hope to see them mounted and on the road.
Walton
Old Sep 26, 2013 | 09:53 AM
Andy Roe's Avatar
Andy Roe
For 17" wheels, 36psi all round. For 16" it's 36 front and 44 rear as per the sticker.
Old Sep 26, 2013 | 10:27 AM
pi5tolpete's Avatar
pi5tolpete
Walton,
Wheels look good and feel fine. I'm happy. Thanks!
Old Sep 26, 2013 | 12:35 PM
Gus's Avatar
Gus
It is interest to note that different tires require different pressures.
I have run several different tire brands over the years and has e used varied pressures from 28 lbs to 36 lbs. to check that you are running a good pressure use a pyrometer to check tire temp across the width - front and rear - you are looking for an even read. If inside is hotter - too mch pressure , if outsides are hot not enough.
There is a lot more to this , but these as basics should work.
You can grab a pyro for around $50 USD
Old Sep 26, 2013 | 01:40 PM
crg53's Avatar
crg53
Originally Posted by Gus
If inside is hotter - too much pressure ,
Or it could be too much negative camber.
