Momo Competition wheel????
The wheel was from Gert, about 18 months ago. Wasn't much more than a Mod 07 when you added the hub, crest horn button, etc. About $125 more which was worth it to me. First one came damaged in transit. He made it right without hesitation. Great guy to do business with.
Rey Gunn, what trouble are you having? The hub on mine was too large diameter for the plastic clamshell so this needed to be modified ever so slightly.
I don't know if I have the right hub to install it. Problem is, the previous owner gave me the wheel and a couple different hubs but I don't know which one works with it. I've tried both and neither seems to work. Do you think you can take a pic of the hub installed? That might be a good start for me. Or if you have a part #. Thanks a bunch.
Actually not many pics that would help with the install. Most of it is intuitive. There is only one bolt holding on the wheel. If you can't find an install thread, reply here and I'll put some photos and instructions up.
