964 Forum 1989-1994
Carrera RS - stonechips: paint or leave it
Old 09-16-2013, 12:53 PM
911Thrasher
911Thrasher's Avatar
Default Carrera RS - stonechips: paint or leave it
Black Carrera RS, paint is original...but loads of stonechips.
It's not bad, but on black it shows...20years
Wondering whether to get the front end resprayed...or leave the battle scars?What's the general consensus?
Old 09-16-2013, 01:30 PM
BeachBoy
BeachBoy's Avatar
best of both worlds IMO:
not resprayed and no chips.
It's probably as expensive as a respray, but respray is not as good when reselling I would think.
Old 09-16-2013, 02:07 PM
bigunit_271078
bigunit_271078's Avatar
If it was mine i would get the front resprayed and then paintshield applied to protect it. As long as its clear that it had nothing to do with damage to the car I can't see how this would be a negative going forward. A lot of this is to do with me hating stone chips though. It aggravates my OCD haha
Old 09-16-2013, 02:11 PM
boots
boots's Avatar
Re paint,mines been done now,lets the car down ...20 plus years of rs life is a hard life!!
Old 09-16-2013, 02:19 PM
vagluv
vagluv's Avatar
I had the same problem and had mine sprayed. Not an rs, so that could play a part in the decision for you. If youre having it done I would try to have it done in single stage paint if the rest of the car still is. Just to keep it original.
Old 09-16-2013, 09:06 PM
Earlydays
Earlydays's Avatar
I would leave it original with all the "battle scars"...some people will pay a premium for a rare car (like the RS) that has the original patina.....
Old 09-16-2013, 09:16 PM
TONY AIR C2S
TONY AIR C2S's Avatar
I would leave it original. If you can't stand the chips, document before, during, and after shots of work. just my 2 cents
Old 09-16-2013, 10:35 PM
onceover
onceover's Avatar
Are you concerned about reselling the vehicle later?
I'd get it resprayed personally
Old 09-16-2013, 10:43 PM
Mr.Alex
Mr.Alex's Avatar
Pics before judgment, I've seen some chipped fronts, and some almost two-tone fronts, so its hard to tell. Like others said, it depends on what your goals are, but I would get them touched up with 100% matching paint and then have the car detailed well.
Personally I'm waiting till the car really, really needs a re-spray, otherwise, with a detail it satisfies my hooning needs.
Old 09-17-2013, 02:25 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,886 Likes on 2,408 Posts
it's an RS
leave it be.
clearly you drove it, bravo!
Old 09-17-2013, 03:35 AM
Ruf964
Ruf964's Avatar
proper touch ups can be done without a respray and look very nice. then armor shield it for the future. my .02
Old 09-17-2013, 06:02 AM
Zingari
Zingari's Avatar
I'd respray. Having had a very original 993 that showed all minor blemishes when I got my 964 and had a lot of work done including new paint the difference was night and day! If you document the paint job then no reason to not go forward as your are not hiding anything.
I thought about having paint shield or such like applied but as I unrest and they use a petrol based adhesive they cannot be removed without causing damage to the paint underneath. I had a similar problem with the rear arch guards. When they were peeled off to replace them they brought the top layer of lacquer off.
Old 09-17-2013, 08:41 AM
digger
digger's Avatar
I did this with my 993C2S it only had 21k miles immaculate otherwise. The people looking at it expected perfection so decision made. Will be painting the 964 shortly to bring back to a decent level.
I would not have an issue painting an RS and documenting the process.
Old 09-17-2013, 09:40 AM
P-track
P-track's Avatar
Leave it, the stonechips will return if you drive it properly. Original paint will never return...
Old 09-17-2013, 11:08 AM
SuperUser
SuperUser's Avatar
I vote to leave it alone
Quick Reply: Carrera RS - stonechips: paint or leave it
