964 Forum 1989-1994
New Owner, new problems
Old Sep 10, 2013 | 09:39 PM
Richk5's Avatar
Richk5
Default New Owner, new problems
Hi all,
I'm a longtime 964 admirer and came across one recently worth picking up. It has its things that need love but that's all part of the plan. I've been incredibly impressed with the knowledge on these boards. You guys are incredible. Anyway, while driving over the weekend coming off from a stop it idled roughly and died when the accelerator was pressed. Started again and same thing. First thought was DME relay, which I replaced with no effect (at least I now have my spare). I'm thinking ISV cleaning next. Any opinions? Thanks in advance. I'm looking forward to interacting as I bring my new prize back to its glory.
Old Sep 11, 2013 | 09:25 AM
NateSaJack's Avatar
NateSaJack
Hi, sorry can't help re your issues, but welcome!
Where abouts are you?
Old Sep 11, 2013 | 09:56 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Welcome to Rennlist and 964 ownership. Did anyone mention that we like to see pictures yet?
As for the engine stalling, can you give us more details about the car? Is it stock or are there any engine mods such as a lightweight flywheel or DME chip? When was the last time it had a full service? Have the coils and spark plug wires been changed? Do you have access to a Hammer or Scantool? Do you have any DME error codes?
Hopefully, the fix is simple.
Old Sep 11, 2013 | 01:07 PM
justin-in-athens's Avatar
justin-in-athens
+1 on more info. Any dash warning lights? Could be a dying fuel pump or vacuum leak.
Old Sep 11, 2013 | 01:57 PM
Shamus964's Avatar
Shamus964
Stuff I'd check in order:
- Verify that the TSB for AFM connector has been carried out (link)
- Airbox is connected tightly to AFM body, elect. connector tightly fitted, and vacuum canister properly connected
- ISV valve, operational and clean
- Battery grounds tight
- All connections to and from coils properly seated (good time to verify both working (see threads on verifying coils - should be able to run on one)
- Engine oil level - verify not overfilled (see threads on how to check level w/dipstick and verify gauge)
Any recent work done on the car? Oil change, plugs, airfilter etc?
Old Sep 11, 2013 | 02:01 PM
Richard Curtis's Avatar
Richard Curtis
What Shamus said ^. Start with the simple things first.
Old Sep 11, 2013 | 04:10 PM
boxsey911's Avatar
boxsey911
Also check that the oxygen sensor is plugged in (it can accidentally get left unplugged after a service).
Old Sep 11, 2013 | 04:16 PM
Ken D's Avatar
Ken D
Welcome. As this was a recent purchase - if you didn't have a PPI (pre-purchase inspection) performed, then now would be a good time for a PPI (post-purchase inspection).
Old Sep 11, 2013 | 11:10 PM
swftiii's Avatar
swftiii
When I had similar it ended up being the coils.
Good luck and you will love the ownership as long as you take your time and do things right the car will treat you vey well.
Skip
Old Sep 12, 2013 | 03:03 PM
Richk5's Avatar
Richk5
Thanks for all the great feedback already. i won't get a chance to work on it over the weekend but you have given me some places to start. Very much appreciated.
A little more background to answer some of the other questions. It is stock and I didn't mention tiptronic so no flywheel issues. The distributor is vented. When it runs there are no lights on. The lights do come on when starting so the lights themselves are operational, not sure if all the sensors work properly as well. I suppose the Hammer could help with that. I do not currently have one but am trying to see if there is anyone local who might have one I can borrow until I get my own. No good service records but the owner says the oil was changed about 200 miles ago. I took a risk with this car and hope it pays off but I honestly got it for a good enough deal that I am still ahead if I have to put some money and time into it. That is part of the fun of it anyway, I could go find one that was already perfect and pay for it but I want this to be a project to enjoy as well.
I am in the New Orleans area, not sure if any other members are but I look forward to be a part of the community here.
Old Sep 12, 2013 | 03:05 PM
J richard's Avatar
J richard
Does the fuel gauge work and does it have gas in it?
Old Sep 14, 2013 | 01:47 PM
Richk5's Avatar
Richk5
Problem solved. Grounds cleaned and running like a charm again. Going to pull ISV for good measure anyway as I'm sure it can use a cleaning.
