Took a 964 in trade
pi5tolPete,
I added the "basket handle" to my coupe. It fits fine and I personally like the look (certainly way better than ET on the cab!). The only thing you need to be careful of is the install location. The clearances between the brake light bar and both the rear window wiper shaft and the wing as it goes up and down are critical (only about 1/8" either way in your mounting location).
Cheers!
Jim G.
Cheers!
Jim G.
Thanks everyone.
I had her out today and noticed a little bit of a misfire when I was running the gears out. Is this a common issue? Do you think it could be an issue with the distributors?
