Heater duct doesn't quite reach engine fan shroud
The answer should be : Length of spacer before it was cut, and after it was cut, unless you can tell us length of cutoff piece and width of cut and amount of trimming after.
Just saying.
Just saying.
LOL, I wasn't sure if you were pulling my leg or what. For reference, .01mm is ~.0004 inches, which, if you're really measuring, is pretty damn precise (hence my question, "Around?!")
Thanks for all the intel; I'll get this done tomorrow and post back.
Just a suggestion, but I would mount the fan without the spacers in place to see how it fits, then when you are happy, take some measurements for the length of the spacers.
Anyway a few photos to show you that I really measured and that the cut was not the best hence why I filed to finish them off:
required length = 29 plus or minus .5mm
Weissach didn't bother to change or cut my bushings.
I found the blower on its side, with the bolts astray.
At 110/hr you would wonder why they thought the gap was acceptable.
