964 Forum 1989-1994
please help with lower control arm bolt. spinning with bushing.
Old 08-25-2013, 06:06 PM
  #31
ghhally
ghhally's Avatar
It seems as the washers aren't the same. The top seems OEM, the bottom seems not and is thinner. I also suspect that the failure occurred when tightening the bolt. In all cases whether OEM, Powerflex or other it's a tight fit and you can't squash them as seen on the pic.
Old 08-25-2013, 07:09 PM
  #32
Vandit
Vandit's Avatar
Might this be partially a result of overtorquing the fastener? This bolt should only be 63 ft/lbs. The forward bolt is 81 ft/lbs.
Old 08-25-2013, 10:50 PM
  #33
FlyinTomato
FlyinTomato's Avatar
I was never comfortable when taking the car to the garage. They simple tighten everything with an air gun.
Old 08-26-2013, 03:20 AM
  #34
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
The steel top hat bushings are critical in that their length prevents this from happening. They bottom against each other setting the bushing preload and clevis width.
Looks as though the top hat bushing length has been altered as you can see the one bushing is squashed.
Please replace the top hat bushings with good unmodified units at the same time the side member is replaced.
Old 08-26-2013, 10:16 AM
  #35
EMBPilot
EMBPilot's Avatar
Tomato,
hang in there buddy, persevere this, one item at a time and you'll make it out the other end. my bushing install was a nightmare as well. involved having to buy an entirely new control arm. you'll make it through this
Quick Reply: please help with lower control arm bolt. spinning with bushing.
