Ever since I bought my 964 its had a NASTY exhaust rattle..Today..I found the problem
Well guys I was rummaging around in primary bypass threads when I realized other people's primary bypass looked a lot like what I have in my car.
Can anyone tell me if I have one from looking at these pictures? Im going to feel incredibly stupid if I have had one this whole time
No way... that's insane, maybe that's why it blew the hole through my secondary muffler!!!!!
Im going to post another picture, I am 99% sure the cat is still in there, although now I know I dont even have a primary muffler...
THIS IS GREAT NEWS.
I was planning on straight piping the car anyway, now I'm one step closer!!
Unfortunately ive never once heard my cars exhaust without the horrible rattle I have, I can't wait to hear the symphony when I get a g pipe... if I can ever find one!!
THIS IS GREAT NEWS.
THIS IS GREAT NEWS.
Cat by + cup pipe (primary bypass) = often results in a cracked secondary, many people just weld a plate on over the top.
G -pipe will give you a deep rumble.
If you have all three bypassed that gonna be super loud!!!
Originally Posted by BLACK-BETTY:10631821
Yup, I may be wrong but sure looks like a cat bypass to me!
I don't get to drive the car much, but when I do... whats the point of having it quiet???
I believe I do have the cat still (although I could be very wrong!!!)
But after I get my g-pipe.... the cat will be the next to go
My O2 sensor was unplugged awhile back which lead me to believe I had some faux cat, but after some recent research I found some people had to disconnect theirs due to the engine needing extra fuel because of upgrades, and the O2 sensor unplugged does that!
I decided to plug it back in and go for a drive, and the car felt... off... it had power up to 3k, then felt very very flat and horrible, then at 5k it felt like VTEC KICKED IN YO and I got a massive surge of power for a second... the car drove weirdly!!
So I unplugged the o2 sensor again and never looked back
Here are the pictures of the cat(s)! (Yes one metal and one alive)
Originally Posted by BLACK-BETTY:10631881
Yup my apologies, that is a cat in the end! Seen from this angle it's clearer!
A cup pipe and g pipe will be very loud! But it sounds awesome
This may be a stupid question for people but can you paint your exhaust? Not for aesthetics, but to keep it from getting rusted like mine is starting to do?would this protect it, or just make it get even hotter?
Technical Guru
You very well likely have some other fueling issue related to the O2 sensor...
That's about when the resonance flap operates.
The default fuel trim value when there is an O2 sensor error is (0x80) 0% correction. You have to jumper the Motronic ECU under the seat if you want more fuel!
verrrryyyyy interseting... hmm.... thank you for the information!
what would you say would be the first thing to test here? resonance flap?
Jumping in late here.
I was also running a primary bypass with secondary muffler. Started to hear rattle, but could never actually see any problem. Granted, I never took the muffler out and checked in detail, and didn't know that there was a problem with the muffler splitting. Then one day I was looking under the car and recognized that there was a problem. A hole in the muffler heated the fiberglass insulation board enough to melt a hole through the board and eventually melted the lower plug wire insulation and plug boots. One wire was completely bare, but still connected to plug boot. A second wire was melted all the way through and no longer connected to plug boot, and third wire was melted and still connected. The ironic part is that the car still ran very well.
I purchased new plug boots, wire, and connectors and remade the three worn wires. Repaired the insulation board, and have now added a secondary bypass to go with the primary bypass. It runs and sounds great. Maybe a little loud for some people, but I get plenty of compliments on the sound. If I had to drive it everyday, it may be a little loud, but for weekends, DE's, and other random drives it sounds fantastic.
There seem to be plenty of secondary bypass pipes for sale on here. I would recommend buying a used one and giving it a try. I purchased mine used from the forum and plan to keep it. If you do not like it, I am sure someone else out there will buy it from you.
