BatteryPPower Drain
My 1991 C4 has an issue with battery power drain. it will not stay charged over a day. I have checked all the fuse circuits in the bonnet and there is nothing draining the battery there. My alternator light comes on occasionally but the battery charges well and, by he way is new. Anyone got any suggestions?
Thanks for your help.
You state that you checked all of the fuse circuits. How?
The proper way is to use a VOM between the battery and the ground, measure the load, then pull each fuse individually and measure the milliamp draw. See if it drops significantly when you pull a particular fuse. Then you have isolated the culprit circuit, and then go from there.
Also, besides the interior lights, check the glove compartment, bonnet and hood light to see if any are on. You can open each up and immediately feel if the lamp is hot.
Technical Guru
Only a few items are un-fused that can cause a drain if the lights, etc are working. The battery itself, alternator, starter (including engine ground strap), and any aftermarket alarm.
I went through rounds and rounds of investigation to cure an 18.5A drain. Battery would die in 30 mins. The metal coiling on the heat exchanger broke away from its sheathing and tore its way through the big red wire on the starter.
Check those items next. Good luck.
