Recommend a Steering Wheel - 89 C4
I recently acquired an '89 C4 which I purchased from my Dad. It's bone stock and I don't plan to mod it too much. The one thing I would like to change is the steering wheel though. The circumference is huge yet the grips are thin and stiff.
What 3-prong wheels work well for this car? It does not have an airbag.
I have a MOD-07 as well. I have recovered it to make it thicker, but here is what it looks like
http://www.flickr.com/photos/sharkerp38/7355521122/http://www.flickr.com/photos/sharkerp38/7355521122/ by http://www.flickr.com/people/sharkerp38/, on Flickr
It came with the car, but from what I hear it is a quick swap with the proper adaptor. You also need to defeat the airbag sensor but a quick search on this forum will point you in the right direction for that
I also recommend some Momo wheel, also because for me it was a great increase in tighter steering response.
There are many threads on Momo installation here, and its good to search. Also there is a 'Aftermarket Steering Wheel' thread to give you some other ideas on what to go for.
Of the top of my head you'll need:
Steering Wheel
Horn Botton with proper wiring
Horn button ring so your horn will actually work (~10-15$)
Either a airbag tester or bridge plug (~30$) to eliminate airbag error.
Some sandpaper to trim the steering column.
Steering Wheel
Steering Wheel
Steering Wheel
All I needed was the wheel itself and hub. Horn button came with the wheel, and the horn button ring came with the hub, if I recall correctly. Very simple install. This thread is a good reference. I didn't need to sand anything, fwiw.
I went from the non-airbag stock wheel (should be the same as yours) to the Momo (Cup) Mod-07. Easy swap, steering feels more direct. Perhaps a RS/928 non-airbag type wheel if you want the stock look but a smaller diameter.
