Tire size - 265/40/18 + 225/40/18, C4
I'm looking at a set of Cayman S 18's to use as summer/Autox wheels.
fronts: 18 x 8 ET50 with 235/40 ZR18 Michelin PS2
rears: 18 x 10 ET47 with 265/40 ZR 18 michelin PS2
I believe the wheel sizes are fine, but am concerned on the tire sizes. The OD is about 5% different by my math (Front to rear), so barely within the allowable C4 limit of 6%.
Will these fit? I'm ok with rolling fenders and mildly flatting the oil line as necessary.
Suspension will be H&R Reds + Bilstein HD dampers, RS or slightly more agressive alignment.
Thanks!
Thanks!
Oh, I understand and would certainly prefer to go with 35 series rears, but the wheels come with great PS2's of a taller than stock size. When the time comes to replace them, I'd go with the appropriate size. If the tires don't fit, the wheels lose their appeal.
235/40 & 265/35
8ET50 is fine ... https://rennlist.com/forums/964-foru...nd-photos.html
10ET47 should be fine ... here is 10ET40 which was a tight fit but will be good info for you ... https://rennlist.com/forums/964-foru...ghlight=10ET40
