water in my 911 1990 carrera 4
I have been having water issues with my 1990 Carrera 4, seems that the foot wells (front and rear) seem to have water build up, either when it rains, or i wash the car? i have un blocked the two drains located in the engine area, but the water still appears?
Last edited by Carrera 4; 05-29-2013 at 02:18 PM. Reason: Posted in the wrong area of the forum
You will get better results if you post your 911 tech questions in the 911 forum.
This Help forum is for questions on forum functionality.
IHI KING!
I had similar issues. Mine was caused by clogged drain tubes in the front ventilation box. On my cab, I also had leaks at the door seals between the window and the convertible top.
https://rennlist.com/forums/964-foru...ater-vent.html
