ethenol in fuels
been worryed about this for some time but this seems good info and i have been told that shell v power and bp ultima dont have any ethenal in them could be the way to go
If you use petrol for your family car, classic car, boat, motorcycle, Quad, lawnmower, strimmer, rotavator, chainsaw, generator, pump or any other type of equipment that has a petrol engine, you need to know about Ethanol in your fuel.
What is Ethanol?
Ethanol, also called ethyl alcohol, pure alcohol, grain alcohol, or drinking alcohol, is a volatile, flammable, colourless liquid. Best known as the type of alcohol found in alcoholic beverages, it is also used in thermometers, as a solvent and as an alcohol fuel. In common usage, it is often referred to simply as alcohol or spirits.
Where does it come from?
Ethanol is sustainable and domestically produced from renewable resources such as corn, grains and potatoes.
Why add Ethanol to Petrol?
Ethanol is good for our agricultural economy and helps us reduce our dependency on foreign petroleum products. On the “green” side they are aimed at improving air quality and reducing air pollution from fuel emissions.
What proportion of the fuel is Ethanol?
Permitted ethanol content in petrol is 5% which is to rise to 10% in 2013. However we are led to believe supermarket fuels may already have as much as 10% ethanol blended in. We hear a 15% mix is on its way in the USA.
While this is good for the domestic farmer and our environment, Ethanol can cause serious problems to your engine and fuel system. Generally vehicles built after 1996 have been designed with Biofuels in mind, but earlier cars and engines with carburettors are going to need help. What types of problems have been encountered?
1) Water accumulation in the fuel tank - ethanol absorbs water from the air. The water condenses in the fuel tank and will pull the ethanol out of suspension with the petrol. This is bad news because it strips the octane out of the petrol, leaving you with a layer of octane-poor fuel on top and a water-ethanol layer mixture on the bottom. If this gets sucked into the combustion chamber, you will have poor starting and very rough running with potentially engine damage.
2) Deposit is like to build up - Ethanol when mixed with water readily forms Gums in the fuel system much quicker than fuel without Ethanol. These Gums coat fuel system components including filters, carburettors, injectors, throttle plates and will then form varnish and carbon deposits in the intake, on valves, and in the combustion chamber.
3) Lower fuel mileage, Decreased performance and acceleration. Ethanol contains less chemical energy than petrol does, and this means less mileage for the driver. 3-5% drops in mileage are expected.
4) Corrosion of internal engine components - Water contamination may cause fuel system corrosion and severe deterioration.
5) Contaminants in fuel system – water, degraded rubber, plastic, fibreglass and rust may get drawn in.
6) It could encourage microbial growth in fuel. Ethanol being organic and hygroscopic may allow the growth of fungus.
7) Short shelf life - as short as 90 days
8) Corrodes plastic and rubber - Ethanol is a strong, aggressive solvent and will cause problems with rubber hoses, o-rings, seals, and gaskets. These problems are worse during extended storage when significant deterioration could take place. Hoses may delaminate, o-rings soften and break down, and fuel system components made from certain types of plastics could either soften or become hard and brittle, eventually failing. Fuel system components made from brass, copper, and aluminium may oxidize. The dissolved plastics and resins now in the fuel could end up in blocked fuel filters or gummy deposits.
9) Melts Fibreglass - bikes and boats with fibreglass fuel tanks can have structural failure as the Ethanol will break down and pick-up some of the materials the tanks are made from. Again this material, dissolved from the tank, can be carried through the fuel system and can cause damage to carburettors, fuel injectors and can actually get into the combustion chambers.
Protect Against Harmful Impact of Ethanol Blended Petrol with Frost Ethomix
Frost Auto Restoration Techniques introduces an additive to protect against the harmful impact of Ethanol blended petrol. Frost Ethomix additive will combat the significant damage Ethanol blended fuel can cause to cars, motorcycles and non-road equipment that do not have compatible fuel systems. Ethomix is formulated to prevent corrosion in fuel systems and internal engine components, gum and resin build-up, clogged carburettors, injectors, filters and fuel lines, plus aggravation of water and moisture problems in fuel storage or unused engine situations.
Prevents corrosion in the fuel system & internal engine components
Protects against gum & resin build-up & carbon deposits
Prevents clogged carburettors, injectors, filters & fuel lines
Compatible with 2 & 4 stroke petrol engines
Stabilizes Ethanol-blended fuels
FAQs
Will the Ethomix additive, when added to pump petrol, counteract all the problems Ethanol blended fuels will cause to Classic Cars?
We think we have a pretty good product, but regrettably it will not cure all the ethanol issues.
Can you provide details on how Frost Ethomix protects against the effects of ethanol?
Frost Ethomix additive contains several functional components, a pHe buffer to control acid formation, a filming corrosion inhibitor to protect ferrous metals and a polymeric dispersant which provides the detergency claims.
What tests have been carried out to prove it works?
Frost Ethomix has been tested using industry standard test methods, ASTM methods for corrosion and pHe and CEC test protocols for detergency performance.
Not only that, in 2012,Frost Ethomix passed the fuel stability additive test programme and now endorsed by the Fenderation of British Historic Vehicle Clubs (FBHVC) as a fuel additive for protection against corrosion in metals.
In particular, can Frost Ethomix prevent galvanic corrosion in carburettors for example where electronically dissimilar metals are used?
Frost Ethomix will not protect against galvanic corrosion as this is a metallurgy issue. There are no corrosion inhibitor additives which can overcome galvanic corrosion.
Will Frost Ethomix mix with other additives?
Frost Ethomix Additive is compatible with leaded petrol and lead replacement additives.
What materials should be changed or avoided (or regularly checked)?
Zinc and galvanised materials, Brass, Copper, Lead / tin coated steel. (Aluminium), Buna-N (seals), Neoprene (seals), Urethane rubber, Acrylonitrile-butadiene hoses, Polybutene terephthalate, Polyurethane, Nylon 66, Fibreglass-reinforced polyester and epoxy resins, Shellac, Cork.
Other Readings
1) Assessing compatibility of fuel systems with bio-ethanol and the risk of carburetor icing Report. (Stephen Wall, QINETIQ/10/02471, 29 October 2010)
What is Ethanol?
FAQs
Other Readings
Hi Ray. Not sure about BP Ultima but according to this thread Shell Nitro contains 5% ethanol. See post 14. Rob
http://www.mbclub.co.uk/forums/amg-p...-launched.html
It i very difficult to figure out if our cars cope with ethanol. The information is correct and matches my experience. The standard fuel for Europe is an E5 these days, in Germany E10 is also available. US pumps has had E10, upto E12 (12% ethanol by volume) for years now. The US actually imports a lot of their ethanol from Brazil at the moment, because of the bad agricultural results of the last year(s).
Gumming is not so much a problem. Chemically ethanol burns cleaner than gasoline, due to the lack of long carbon chains in the fuel, which are difficult to combust. Deposits are generally now an issue. The additives however may be to avoid the separation of ethanol with the gasoline. Also stabilizers are added to the Ex to avoid aging. These additives could cause some issue but generally dont.
I am most worried about the rubbers. Most older style rubber compounds dont tolerate ethanol and they swell up. Also the materials in the fuel lines (brass, copper) clog the injectors, a big issue for DI engines.
Personally I avoid using any fuel greater E5 on my old cars, mdern cars have been developed with teh Ex in mind.
Also, bear in mind that ethanol starts much worse than gasoline at low temperatures. Never put E85 / E75 in the engine if you expect it to start below 20F / -10C.
There are a host of other issues with ethanol. mainly related to the valve seating wear. I guess for as long as we can, steer clear as much as we can and we should be ok.
I remember a similar discussion with my aircooled VW's when leaded fuel was stopped. A lot of products hit the market to supplement the lack of lead but it's not something thats seems to worry people any more.
BG just started making a fuel system defender that is supposed to protect the entire system from ethanol for 6 months . I have seen some test documentation. It is just being introduced in Canada. For disclosure I work for the distributer here in Ottawa.
