94' 964 widebody/turbo look
What is factory the diameter of the front/rear sway bars for a 1994 964 turbo-look (should be the same as the 94 turbo, I presume)...
I’ve read of 21mm/front and 22mm/back and was under the impression the dimension of the front diameter should be slightly higher than the rear one, because of the 964 weight ratio.
Finally, is there any recommended upgrade out there, i.e.: H&R? Remember, this is a c4...
